2014 Jeep Wrangler Cold Start Ticking
For a lot more information you might try a friends site David at MotorCityMechanic on YT.
He covers the issues with the 3.6 and more.
https://www.youtube.com/watch?v=OIzJiKLjGt0
https://www.youtube.com/watch?v=XkrwxVVcjsg
https://www.youtube.com/watch?v=OUIQuwnYqbs
Suggested Repair
Check the engine oil level and whether the lower front pulley is loose or wobbling. Briefly remove the drive belt and start the engine to see if the tick is from an accessory or bracket. Also inspect the 3.6 rocker arms early, since failed rollers can cause cold-start ticking and may require rocker replacement before the cam is damaged.
Conversation Summary
A 2014 Jeep Wrangler ticks when first started, then the noise stops once the engine warms. The owner also noticed slight shake in the large lower front pulley. Experts asked for a close video and suggested checking oil level, pulley tightness, and whether the noise remains after briefly removing the drive belt. They also noted that the 3.6 engine commonly develops rocker-arm roller failures that begin as cold-start ticking and can worsen if not caught early.
