1999 Jeep Wrangler Overcharging
RJP56
I have a 1999 Jeep Wrangler 4 cyl, standard with 80,000 miles on it. The vehicle has a dead short to ground which is I believe is taking my alternator out. After looking, it's not in any of the fused cuircuts. I checked all the grounds, they look good also. The second alternator is putting out 18.5-19 volts. All the gauges on the dash also drop as I rev up the engine and return to normal when idling. Any ideas?
Sep 17, 2007 at 6:41 AM
  • 75,988 POSTS
[quote:01cb6b15e3="rjp56"]I have a 1999 Jeep Wrangler 4 cyl, standard with 80,000 miles on it. The vehicle has a dead short to ground which is I believe is taking my alternator out. After looking, it's not in any of the fused cuircuts. I checked all the grounds, they look good also. The second alternator is putting out 18.5-19 volts. All the gauges on the dash also drop as I rev up the engine and return to normal when idling. Any ideas?[/quote:01cb6b15e3]
Your voltages are too high its over reconditioning the battery its killing it. about the dead short entirely remove all wiring at alternator-dead short diasappears you have a bad alty-
Sep 17, 2007 at 7:04 AM
Suggested Repair
The 18.5-19 volt reading is too high and is overcharging and damaging the battery. Disconnect all wiring at the alternator; if the dead short disappears, the alternator is faulty and should be replaced.
Conversation Summary
The owner of a 1999 Jeep Wrangler with 80,000 miles reports a suspected dead short to ground that is not in any fused circuit and appears to be destroying alternators. Grounds look good, a second alternator outputs 18.5-19 volts, and the gauges drop when the engine is revved then return to normal at idle. The expert says the voltage is too high and is overcharging and killing the battery, and advises removing all alternator wiring—if the short disappears, the alternator is bad.
