this is a new thing for Eugene - we'll be going along, doing fine - 70 miles/hr or so... and he'll just start to stall....like he's not getting any gas - and he'll buck until i get him to the side of the road. when idling - he's smooth - but when i try to give him gas to go, he stalls. they have changed the crank sensor - and we thought that was was the problem - but he did it again....now the kicker is - if you let him sit for about 15 minutes - he'll start up, and run like nothing is wrong! the garage can't duplicate what's happening - so are only going on my description. has this happened to anyone else?
1998 Jeep Wrangler Stalls While Driving
this is a new thing for Eugene - we'll be going along, doing fine - 70 miles/hr or so... and he'll just start to stall....like he's not getting any gas - and he'll buck until i get him to the side of the road. when idling - he's smooth - but when i try to give him gas to go, he stalls. they have changed the crank sensor - and we thought that was was the problem - but he did it again....now the kicker is - if you let him sit for about 15 minutes - he'll start up, and run like nothing is wrong! the garage can't duplicate what's happening - so are only going on my description. has this happened to anyone else?[/quote:a874203b19]
Lets try the fuel system 1st-have the fuel pressure check
thanks
You have changed the fuel pump but do you know that its producing the correct pressure? You need to monitor it -to catch the culprit on the act or it could be an ignition component that's going whack
You might be right with PCM or get it reflash and see what happens-
Thanks
thanks
Suggested Repair
Check fuel pressure while the stall happens and test or substitute the auto shutdown (ASD) relay, which powers the coil, injectors, and fuel pump. If those check out, have the PCM/ECU reflashed; that resolved the similar stalling.
Conversation Summary
A 1998 Jeep Wrangler 2.5 stalled and bucked at highway speed as if starved of fuel, then idled but died when throttle was applied. After about 15 minutes it restarted and ran normally. A crankshaft sensor replacement did not fix it, and the shop could not reproduce the fault. Another owner with the same pattern had already replaced the fuel pump, filter, sensors, relays, ignition parts, and ECM, with fuel pressure at 50-60 psi, and found the problem reset when the ignition was cycled. The expert advised confirming fuel pressure, considering an ignition fault or PCM reflash, and testing or replacing the ASD relay. After an ECU flash, that Jeep ran normally for a day and a half.
