Engine wont start and run what could it be?
RMINGES
  • 2000 JEEP WRANGLER
  • 6 CYL
  • 4WD
  • 74,000 MILES
Jeep cranks over but won't start,item installed so far new fuel pump,coil pack,cam sensor... no fuses blown but not getting 12 volts to coil pack, manual says to check the "auto shut-down relay"... Can not find the relay and parts store says vehicle don't have it, manual states -
http://www.2carpros.com/forum/automotive_pictures/552450_IMG00082_1.jpg
this is only on 2000-6cyl which i have?
Thursday, September 24th, 2020 AT 6:13 PM (Merged)
BLACKOP555
  • 10,371 POSTS
ASD is what it may be called. Will b in the main fuse box. Your vehicle should have them not just a 2000. If the relay was bad tho you would have no injector pulse either
RMINGES
Relay was marked as asd, replaced with known good relay (horn-same relay-same size and amp) STILL no fire. Can smell gas, but won't start?
BLACKOP555
  • 10,371 POSTS
Have you checked the control side of the relay it should click. Check to see if you got 12v on terminal 30 in the box
RMINGES
The relay does click and #30 is the a/c fan relay and just like the asd relay it has 12v coming from the battery and 12v when ignition switch is turned on
BLACKOP555
  • 10,371 POSTS
I was saying leg 30 on the relay spot in the box not fuse 30.
I am left to believe that the asd part of circuit is good. Next thing to do is tell me what your not getting to the coil. +12v constant or the negatiave pulsing 12
