Booster
KAJKEJ
  • 2000 JEEP WRANGLER
  • 6 CYL
  • 4WD
  • MANUAL
  • 66,000 MILES
The brakes were working fine this morning. After work the brakes are very stiff and you really need to push hard to engage them.
Monday, January 11th, 2010 AT 6:05 PM
DOCFIXIT
  • 18,828 POSTS
Most likely vacuum brak booster failure simple test engine off pump brake pedal 4-5 times hold down with some pressure start engine pedal should go to floor if no then booster at fault
Monday, March 15th, 2021 AT 2:36 PM
