1997 Jeep Wrangler BATTERY GAUGE
1997 JEEP WRANGLER
60,000 MILES • 4 CYL • 4WD • MANUAL
RAULSP
Hi everyone, this is my first post on these forums:
I am driving and suddenly the battery gauge goes all the way to the right (to 19) and a red light comes on saying to check my gauges. However the car keeps on driving noramlly. If I turn the engine off it won't turn on again, it is totally dead (as if it didn't have a battery, none of the lights come on). Suddenly everything is back to normal and I can start the engine again, although if I let the RPM to go below 1000 the engine tries to quit. After driving for a while the jeep runs totally normal until the whole thing happens again (so far it has happened twice within one week).
Any help?
Thank you,
Raul.
Mar 29, 2008 at 4:44 PM
BMRFIXIT
  • 19,053 POSTS
clean and tighten the battery cable terminals
Mar 29, 2008 at 11:57 PM
RAULSP
Thanks! I'll try that.
Raul.
Mar 30, 2008 at 7:46 AM
RAULSP
I checked the battery terminals and cables. They are clean from the last time I replaced the battery (about 5 months ago).
They are also tight.
What else could it be?
Raul.
Mar 31, 2008 at 7:09 AM
BMRFIXIT
  • 19,053 POSTS
then you need to check the charging system
check the alternator
check for a loose wire
Mar 31, 2008 at 5:07 PM
