1985 Jeep Wrangler Ignition Switch Removal
1985 JEEP WRANGLER
224,000 MILES • 6 CYL • 4WD • MANUAL
DENNISGR59
How are the ignition swich removed on a 1985 Jeep.
I find no hole in the tumbler to press to release switch.
Jan 22, 2010 at 5:41 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The ignition switch is on top of the lower part of the steering column, inside the vehicle.
Put the key in the lock and turn to the OFF/UNLOCKED position.
Disconnect the battery ground cable.
Detach the wire connectors at the switch.
Remove the switch screws.
Disconnect the actuating rod from the switch and remove the switch.
Move the switch slider all the way down the column. Move it back toward the steering wheel two clicks to the center OFF/UNLOCKED position.
Engage the column actuating rod in the switch slider and fasten the switch down.
Connect the wire connectors, then the battery ground cable.
Jan 22, 2010 at 7:04 AM
