1987 Jeep Comanche Stalls After Running
JEEP
RS2755
I have a 1987 Jeep Comanche p/u with over 100+ mileage,4cly standard. The problem is it starts and runs fine...for 10 or 15 min and justs stops running,wait maybe 45-1 hour and it can be started right back up-no sooner.The coil checks out good and have replaced the ignition module,still have the same problem,anything? Thanks.
May 16, 2007 at 12:22 PM
MERLIN2021
  • 17,250 POSTS
check the distributor...wires and pickup inside and for sideplay...may need a new one.
May 17, 2007 at 5:29 AM
RMASER
  • 11 POSTS
your trouble is most likely your crankshaft position sensor,that is what happens when it gets bad.
It is a hard sensor to change,it is on the trans bell housing on the top,with a few extensions on your rachet you can get to it
Dec 1, 2008 at 12:52 PM
COMANCHE21
[quote:f28c541bda="rmaser"]your trouble is most likely your crankshaft position sensor,that is what happens when it gets bad.
It is a hard sensor to change,it is on the trans bell housing on the top,with a few extensions on your rachet you can get to it[/quote:f28c541bda]
quote from comanche21...
I agree with "rmaser", I had the same problem with my 1989 Jeep Pioneer truck I6 engine. It's tough to get to, but easy repair. On an automatic unbolt the bracket that holds the transmission cable and let it hang down, that will give you enough room. (A swivel extension or a wobble extension makes it easier). Good luck, comanche21.
Mar 10, 2010 at 3:25 AM
MERLIN2021
  • 17,250 POSTS
Did either of you boys check the date on this post? Probably fixed by now! Crank sensor is possible, but if it runs, DVOM it hot and cold!
Mar 10, 2010 at 6:59 AM
COMANCHE21
[quote:0e41febf2b="merlin2021"]Did either of you boys check the date on this post? Probably fixed by now! Crank sensor is possible, but if it runs, DVOM it hot and cold![/quote:0e41febf2b]
From comanche21 (per merlin2021 quote)
Did check the date! But there are probably more than one person with this problem and the more suggestions the better as the answer I gave solved the problem.
Mar 13, 2010 at 3:58 PM
MERLIN2021
  • 17,250 POSTS
It's three years old, and he didnt ask anymore questions...more than one the thing can go wrong, dont get too full of yourself.
Mar 13, 2010 at 11:35 PM
Suggested Repair
Inspect the distributor wires, internal pickup, and shaft side play, and replace the distributor if needed. Also test the crankshaft position sensor hot and cold with a DVOM; if faulty, it is on top of the transmission bellhousing and can be reached with extensions.
Conversation Summary
A 1987 Jeep Comanche with a 4-cylinder and manual transmission starts and runs for 10 to 15 minutes, then stalls and will not restart for 45 to 60 minutes. The coil tested good and the ignition module was already replaced. An expert suggested checking the distributor wires, pickup, and side play. Other users reported the same symptom from a failing crankshaft position sensor on the transmission bellhousing. The expert later said a crank sensor is possible and should be tested hot and cold with a DVOM.
