When you turn key On, do you hear the fuel pump buzzing for a few secs. No -check the fuel pump relay inspect for good connection and test the coil and switch side of the relay then comeback-[/quote:ddb490fbbb]
Yes the fuel pump works for a few seconds when i turn the key. I checked the relay by jummping a wire bettwen the 87 30 pins pump ran all the time but engine was the same ie starts for 10 seconds and stops. It feels like the fuel gets turned off after it starts ethier at the pump or injectors.
Thanks heaps for your help Tony[/quote:ddb490fbbb]
Okay check the crank sensor on the transmission bellhousing and cam sensor in the distributor-check their connections
Could be that computer is not getting the crank signal and not energizing the injectors- check the crank sensor thoroughly.
Tuesday, September 18th, 2007 AT 6:12 AM
