1997 Jeep Grand Cherokee AC Water Leak
JEEP
T_LACOSTE
1997 Jeep Grand Cherokee Laredo 161,000 miles 4.0 V6. Where can i locate the air conditioner box to check for possible buildup in the drain hole? I am getting a significant amount of water in the passenger floor board when i use the A/C. I have been told by several to clear that hole but i can't find it and even took it by a repair shop and he couldn't find it. He told me that he could just drill a hole in the firewall for me...but no thanks to that. Thanks for your help!
Jun 14, 2007 at 5:07 AM
BRUCE HUNT
  • 3,754 POSTS
I am not sure exactly where the location is, so if someone else does that is great. What I offer is for those that have this problem to on the passenger side of the vehicle for a hose hanging down and that should be the drain. Sometimes you need to look pretty hard but it will be there.
Jun 14, 2007 at 8:17 AM
Suggested Repair
On the passenger side underneath, look carefully for a hose hanging down from the A/C evaporator box; that should be the drain. Clear any buildup in it. Do not drill a hole in the firewall.
Conversation Summary
The owner of a 1997 Jeep Grand Cherokee Laredo has water on the passenger floor when the A/C is used and cannot find the evaporator drain hole. A shop suggested drilling the firewall, which the owner declined. The expert was unsure of the exact location but advised looking carefully on the passenger side for a hanging hose that should be the drain.
