1998 Jeep Transmission Sensor Codes
1998 JEEP
JOHNBUKO
  • 9 POSTS
i flushed my transmission fluid a couple months ago using regular dexIII. a week later the mil light started coming on showing trans. codes. all types of sensor codes, shift, trans cntrl syst mal, trans range sens malf. i thought maybe i should have used mopar fluid but i was told the fluid would not set off all these sensor codes. also i was told that i should have the pcm flashed but i have not done that yet. has anyone experianced this before?
Dec 12, 2006 at 3:19 PM
BRUCE HUNT
  • 3,754 POSTS
What did you flush it with? Was there a filter in there and did you properly get it replaced?
Dec 17, 2006 at 11:51 PM
JOHNBUKO
  • 9 POSTS
flushed it with one of those flush machines. did not take the pan down and change the filter though. do you think the filter could have come apart during the flush?
Dec 18, 2006 at 12:03 PM
BRUCE HUNT
  • 3,754 POSTS
The worry I have is that the filter could have disintegrated (sp) or come apart, etc. The flushing is not an activity I would recommend. The dropping of the pan, replacing the filter, cleaning things you see and putting in a gasket with the cover is the correct route.
Dec 19, 2006 at 12:52 AM
Suggested Repair
Do not machine-flush the transmission. Drop the pan, replace the filter, clean the pan, install a new gasket, and refill with the correct fluid. A filter that came apart during the flush may be causing the sensor codes.
Conversation Summary
The owner of a 1998 Jeep flushed the transmission with Dexron III using a flush machine without dropping the pan or changing the filter. About a week later the MIL came on with multiple transmission sensor, shift, control-system, and range-sensor codes. The expert said flushing is not recommended and that the filter may have disintegrated. The advised repair is to drop the pan, replace the filter, clean what is visible, and install a new gasket.
