1977 Jeep CJ5 Sputters Under Load
1977 JEEP
JUST JEEPS
I have a 77 cj5 with original 304 with 77,000 +- miles
engine jumped time, removed cover and found cam gear jumped off the keyway, replaced with new gears, chain etc. problem is while jeep is under a load, taking off, accelerating etc, it spits and sputters.
is it possible for cam to be out of time with the crank?
new items include:
timing gears and chain - made sure they were dot to dot several times
new timing gears and chain (twice replaced)
new dist with all internal components, cap and rotor
new wires and plugs
new carb
new coil
new fuel pump and filter
what am i missing or done wrong????????????
Jun 30, 2007 at 10:48 AM
  • 75,988 POSTS
Maybe its in the exhaust stroke instead on the compression BTDC 0deg. Did u put engine on TDC before setting all the marks as illustrated. If not sorry to say you're going back in again
https://images.2carpros.com/forum/automotive_pictures/12900_baby_smoking_2.gif
I'll be taking a break see you later okay
Aug 6, 2007 at 8:43 PM
Suggested Repair
Set the engine to true top dead center on the compression stroke, not the exhaust stroke, then verify the timing marks are aligned dot to dot. If the marks were set on the wrong stroke, the cam is 180 degrees out and the timing cover must come off again to correct it.
Conversation Summary
The owner of a 1977 Jeep CJ5 with a 304 said the engine jumped time when the cam gear left the keyway. After replacing the timing gears and chain twice, plus the distributor, wires, plugs, carburetor, coil, and fuel pump, it still spits and sputters under load. The expert said the cam may be timed to the exhaust stroke instead of compression TDC and that the engine must be on TDC before the marks are set, which may require opening the cover again.
