2000 Jeep Liberty Can you suggest what the problem might be
LHINER
  • 2000 JEEP LIBERTY
  • 4 CYL
  • 4WD
  • 45,000 MILES
Hi guys,
Ok, so it has been awhile since I have had a vehicle that won't start. I have lot's of battery power, but when turning the key to start the vehicle it makes a "clicking noise". It this likeyl to be the starter? Or can you suggest what the problem might be?
Thanks,
Lee
Monday, September 28th, 2009 AT 10:00 AM
  • 109,740 POSTS
Lee:
Honestly, it sounds like a weak battery. The battery may show 12+ volts until it's under a load. What I suggest is to take the battery to a parts store and have them load test it for you. That way you'll know if it is the battery or the starter. Also, make sure the battery terminals are clean and tight including the ground on the engine.
Let me know what you find.
Monday, November 9th, 2009 AT 1:37 PM
