need to confirm my question recieved
JEEP GRAND CHEROKEE LAREDO
RQUARTERS2
2000 jeep laradeo 78300 mi. 6cyl want to install 2 emergency light bars to jeep. how do i wire them usinf an on-off switch and relay to reduce heat?
Aug 31, 2007 at 3:12 AM
2CARPRO JACK
  • 11,533 POSTS
A 25 amp fused main power into each realy (1 for each light bar)Power out to the lights,a ground for the relay use the switch in the Jeep to supply 12 volts for the relay trigger, that way you dont have any heavy draw on the wiring in the cab of the Jeep ,
https://images.2carpros.com/forum/automotive_pictures/1639_wiringdiag_small_1.gif
Sep 1, 2007 at 1:27 AM
