fuel system problems
PEPPER
I HAVE A 1997 JEEP GRAND CHEROKEE IT HAS OVER 100,000 MILES, IT IS A 6 CYL. I PUT SOME INJECTOR CLEANER IN MY FUEL AND IT STARTED MISSING REALLY BAD. THE MORE I HAVE DRIVEN IT THE LESS IT HAS BEEN MISSING. WHAT WOULD HAVE CAUSED THIS TO HAPPEN? ALSO COULD SOMEONE TELL ME WHERE TO FIND THE FUEL FILTER? SOMEONE TOLD ME TO CHANGE IT, THAT IT MIGHT HELP WITH THE MISSING. THANKS,PEPPER :cry:
Oct 3, 2007 at 3:50 AM
  • 75,988 POSTS
It is actually inside the gas tank. Replacing it requires draining and removing the fuel tank, removing the access panel on top of the tank. You will also find the fuel pump in this location. You might as well replace it if you have gone to the trouble of removing the tank.
Oct 14, 2007 at 11:18 PM
