1997 Jeep Grand Cherokee CEL P1494
STANG33LB
I have a 1997 Jeep Grand Cherokee Laredo with 120,000 miles. 4x4 Automatic Trans.
First part, I have a "check engine" light on solid all the time that throws a p1494 Code and have had the Leak Detection Pump Switch Replaced as well as the Vacuum tested. The light will go off after a repair is made and come on within the next 5-10 days. I am not sure where to turn from here.
Second part, sometimes while driving, I will hit the gas and the Jeep will hesitate for a few seconds, then there will be some kind of knock sound coming from the front (I believe the driver's side) then the Jeep will run great. I have done a tune up (plugs, wires, distributor and cap) and still have the problem. What is weird is that this problem is intermittent and happens 1-3 times per month.
Any suggestions on either of these topics would be greatly appreciated.
Jun 13, 2007 at 5:53 AM
SERVICE WRITER
  • 9,123 POSTS
For the code, I would recommend smoking the system. When looking for the smoke, the intake gasket should be watched as well as that may be part of the second problem.
Jun 13, 2007 at 8:03 AM
Suggested Repair
Smoke-test the EVAP system for the recurring P1494 leak and inspect the intake gasket while testing, since a leak there may also cause the intermittent hesitation and knock.
Conversation Summary
A 1997 Jeep Grand Cherokee Laredo has a solid check-engine light with code P1494 that returns within 5-10 days after the leak detection pump switch was replaced and the vacuum was tested. It also intermittently hesitates under acceleration, makes a knock from the front driver's side, then runs normally; a tune-up did not fix it. The expert recommends smoking the system and watching the intake gasket, which may relate to both problems.
