For starters clean out the throttle bore (where the air intake tube goes to engine) with some carb spray and a rag. On the throtle body is the IAC motor (lowest sensor on throttlebody) held on with 2 Torx screws. Remove it and clean it well with carb spray, careful not to loose the small o'ring
SPONSORED LINKS
Monday, October 29th, 2007 AT 7:48 AM
