2004 Jeep Laredo Car won't start
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
WMUELLER
My car was running fine, however today when I turned my car off, during this process I turned it on again. After this my car was dead. I won't even turn on again, not even crank the engine. I checked the Ignition Fuses and nothing seems to be wrong. Could it be the starter solenoid or the starter itself? How hard are these to replace?
Thank you for your help.
Sep 25, 2010 at 1:12 PM
CJ MEDEVAC
  • 11,000 POSTS
See my profile, I do not know your rig
IS YOUR BATTERY CHARGED?
IS YOUR ALTERNATOR CHARGING?
WILL IT JUMP OFF?
Read thru this----Things in it may help you!
https://www.2carpros.com/forum/1993-jeep-cherokee-will-not-start-vt503764.html?highlight=
Let me hear some good news!
Your Turn
The Medic
Sep 25, 2010 at 3:46 PM
WMUELLER
yes the battery is in great condiion I had it check yesterday. I have no power at all. The automated button on my key won't even let me lock my doors anymore, I have no lights on, I tried to jump the car nothing. If I try to turn the car on, no clicking sound nothing. Does this info help?
Sep 25, 2010 at 11:17 PM
CJ MEDEVAC
  • 11,000 POSTS
PRETTY MUCH its telling you to take apart every connection to the starting system, clean it (wire brush, etc) then put it back together and tighten it well!!!!
You could do the EZer stuff 1st, try to start it up each time, as you progress on thru your system.
I tried to not leave out CONNECTIONS, so that no stone would be left unturned!
I just sorta directed these particular pictures at CJs and Older Fords (rigs I know well)..............your system is very similar (just read what the post says to do....where to find!
It really sounds like you are not getting power from out there, on the Battery connections and related components.......If you are charged!
A Repair manual, as I mentioned in my profile might help you Now and Later, Especially if you keep it in your vehicle.
May the FORCE BE WITH YOU!
Your Turn
The Medic
Sep 26, 2010 at 12:18 AM
WMUELLER
Thank you. I will let you know if that works. I may just buy a new connections. So you don't think it is the starter or relay?
Sep 26, 2010 at 1:10 AM
CJ MEDEVAC
  • 11,000 POSTS
The only thing you should buy, RIGHT NOW, is a SMALL WIRE BRUSH (a little larger than a toothbrush!)
If your battery connectors are broke or beyond cleaning----or cables frayed up........Buy Them too!
If your starter were bad-----all accessories would still be powered
It could be your SOLENOID aka STARTER RELAY........This is USUALLY the point where your battery connects to EVERYTHING requiring electricity.
In my pics, in the LINK, you can see the Battery cable (1) sandwiched together with (wire 3) and (wire 4)................I know yours is a newer version than mine...................But with them "SANDWICHED" on that one post----------They do not even "RUN THRU" the solenoid. They all connect there, and provide power to everything!
So basically, I am saying this is where they all splice together..........The solenoid post is nothing more than a "WIRE NUT" (like on household wiring)
Follow the Positive and Negative battery cables anything they connect to, remove, clean, tighten back well!
Go back and review the LINK.....at the end is "FUSABLE LINKS".......a manual might show you locations of yours, so you can check them.
Get motivated.......get on it.......give me some good news!!!
The Medic
Sep 26, 2010 at 4:13 AM
