2000 Jeep Grand Cherokee Brake Drag
The transmission fluid should not have a pink tint, but be very pink and clear, maybe I misunderstood.
Tell the Son to study hard!!
Suggested Repair
Return the Jeep to the shop that did the recent front brake job and have them recheck that work. A sticking driver-side caliper, or slides and hardware that were not cleaned and lubricated, can drag the brake, cause hesitation and a wheel-well smell, and keep the vehicle from rolling in gear until the throttle is applied.
Conversation Summary
A 2000 Jeep Grand Cherokee Laredo intermittently hesitates on acceleration and smells from the driver-side front wheel well, usually after about 10 minutes of driving. The check engine light stays off, and the problem often does not return the same day after the vehicle is parked. It began after front rotors and pads were replaced. During an episode, the vehicle will not roll in drive or reverse until the throttle is applied, then stops when the pedal is released. The expert recommends returning it to the mechanic to recheck for a hanging brake, such as a sticky caliper or poorly cleaned and lubricated slides and hardware, and notes that healthy transmission fluid should be very pink and clear.
