1994 Jeep Laredo My Car Won't Start The First Time.
DESI3689
  • 1994 JEEP GRAND CHEROKEE LAREDO
Engine Mechanical problem
1994 Jeep Laredo All Wheel Drive Automatic
i was wondering why my jeep never cranks up the first time.I had the alternator, the starter and the battery all checked out and they were fine. Could you tell me what 's wrong and/or how I could go about fixing this problem? Thanks for your time.
Wednesday, September 2nd, 2009 AT 2:55 AM
  • 109,885 POSTS
I would start with checking fuel pressure drop off. What that means is, when you shut the key, the fuel system should maintain pressure for several minutes and then drop to a point and stop. If you drop to 0psi very quickly, there is a leak in the system and that would cause the vehicle to be hard to start until the pressure builds.
Here is a How To for checking pressure and drop off. You will need a gauge to check it, but most parts stores will lend or rent the tool. Check if out and let me know what you find.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Monday, November 9th, 2009 AT 11:36 AM
Related Engine Not Running Content
