1999 Jeep CJ7 COMPUTER CODES
279,000 MILES • 6 CYL • 4WD • AUTOMATIC
MAYAN-TJ
HOW CAN I REPAIR THESE CODES
P0118
P0138
THANKS.
Jan 7, 2008 at 11:54 AM
BLACKOP555
  • 10,386 POSTS
P0118 is coolant temperature circuit high input, to fix this check the wires going to the coolant sensor and to the wiring harness.
P0138 - Left Bank Downstream or Downstream and Pre-Catalyst o2 Shorted to Voltage low. that is caused bye a bad catalytic converter or a bad pre and after o2 sensor may also be caused due to the P0118 code.
Jan 7, 2008 at 12:05 PM
