1983 Jeep CJ-7 Won't Go Over 45 MPH
1983 JEEP
BUBBAROT
i have a 1983 cj-7 jeep with a 2.5L engine with about 10,000 miles on a rebuilt motor.it has been running pretty goodfor a while now and then all of a sudden the other day it started spitting,and wont hardly go over 45 miles an hour.i have already put in the past 6 mnths a new battery,spark pluggs,and plugg wires.it also seems to be blowing out some smoke was black now light grey,mainly upon starting.someone said the old 1 bbl carb might need replacing.any ideas please thanks,justin
Mar 25, 2007 at 12:19 PM
MERLIN2021
  • 17,250 POSTS
could be is it dirty? maybe some gumout might help...the other thing, could be a clogged converter.
Mar 27, 2007 at 8:44 AM
MERLIN2021
  • 17,250 POSTS
Did you check the catalytic converter? If it clogs you will get same symtoms have someone rev the jeep and you check the amount of exhuast from the pipe!
The oter thing is timing, the chain may have jumped a tooth...
Mar 28, 2007 at 7:29 PM
MERLIN2021
  • 17,250 POSTS
Also check the egr valve for stuk open condition
Mar 29, 2007 at 7:19 AM
Suggested Repair
Check the carburetor for dirt or gum and try carburetor cleaner. Inspect the catalytic converter for clogging by comparing exhaust flow while the engine is revved. Also check ignition timing in case the timing chain jumped a tooth, and test the EGR valve for a stuck-open condition.
Conversation Summary
The owner of a 1983 Jeep CJ-7 with a rebuilt 2.5L engine reports sudden spitting, difficulty exceeding about 45 mph, and smoke that changed from black to light gray, mainly at startup. A new battery, spark plugs, and plug wires were installed recently, and a one-barrel carburetor replacement was suggested. The expert recommends checking for a dirty carburetor, a clogged catalytic converter, a jumped timing chain, and an EGR valve stuck open.
