1986 Jeep CJ7 ENGINE
145,000 MILES • 6 CYL • 4WD • MANUAL
BUDMAN45
i've replaced carburator, spark plugs,wires, distributor cap, rotor. i put a new engine in and still have problems. the engine will backfire and won't run. i've had a mechanic ajust carb., still backfires. went i disconnect plug on back of carburator, it seems to run ok. could this be a problem with the computer or how can i check to see if its an electicral problem? is there a way to check the computer system or do that model and year have a computer system for the engine?
Jan 4, 2008 at 2:04 AM
BOBO0410
  • 5 POSTS
you can go to almost any auto shop and they can hook it up to a computer and find out what the problem is
Feb 1, 2008 at 4:37 PM
  • 55,770 POSTS
These cars had a problem with the fuel line at the tank go bad and allow air to suck in causing the engine to run lean which it sounds like your problem is.
Dec 18, 2024 at 5:05 AM
