1978 Jeep CJ7 transmission
JACOBSOWELL
  • 1978 JEEP CJ7
  • 6 CYL
  • 4WD
  • 135,666 MILES
I want to know how to properly use the Quadratrac system in my CJ7
Monday, April 12th, 2010 AT 6:59 PM
CJ MEDEVAC
  • 11,005 POSTS
See my profile, I possess a 1979 AMC service manual (The real Jeep Bible, for all Jeep Rigs that year and most years nearby, also). Tells all, general, operation...including diagnosis and repairs.
Just a very light summary on Quadratrac:
Emergency Drive is used ONLY,ONLY,ONLY to get out of some BAD $HIT (When wheels are spinning, locks FRT and REAR together)....And immediatly returned to NORMAL 4 WD, when out of Toilet Situation. Cannot have wheel motion, when you engage it.
Lever beside seat:
Up----High range
Middle----Neutral....To tow your rig
Down----Low range
From high to low----release accelerator pedal...shift into Neutral between 10-15 MPH......into Low BELOW 5 MPH
From low to high---release accelerator pedal 15-20 MPH, shift to Neutral between 5-10 MPH....then into high.
BOTH CASES---Vehicle must be moving, sorta push on thru neutral as you shift.....unless you are about to tow him.
Can and will help you on any other CJ stuff, I know my stuff.
Reply?
Love, Turddog
https://www.2carpros.com/forum/automotive_pictures/411289_GOOD_OLE_WILLY_1.jpg
Monday, April 12th, 2010 AT 7:58 PM
