1996 Jeep Cherokee Temp Gauge Stuck
YTHOUSE
I have a 1996 Jeep Cherokee, 180,000 miles, 4.0L engine, 4WD. I replaced the engine on my Jeep with an engine from a 1997 Wrangler, 4.0L 75,000 miles.
Everything went okay, the new engine starts and runs good, the car drives. The only problem is that the temp guage does not work. The needle stays at the left on the 100 degree mark. I replaced the thermostat but that did not make it work.
Then I noticed that the 1996 block has an extra coolant sensor in the top of the head near the firewall on the drivers side and the 1997 block does not have this sensor. All other ports and connection locations were the same on the 2 engines. So I have that one connector disconnected.
I am guessing that the 1996 computer used data from both sensors to make the temp guage work.
What can I do now to make the guage work aside from drilling a spot in the head to add the missing sensor?
Sep 24, 2007 at 7:28 AM
MERLIN2021
  • 17,250 POSTS
Before I started to drill, I would see if I could find a thermostat housing with the sensor hole already in it! Yes you are right that the cherokee has an extra or seperate sender! Onlt other work around is to try the ect from you 96 and wire the gauge with it!
Sep 24, 2007 at 7:41 AM
Suggested Repair
Before drilling the head, look for a thermostat housing that already has a sensor port. The Cherokee uses a separate temperature sender; another option is to use the 1996 ECT sender and wire the gauge to it.
Conversation Summary
A 1996 Jeep Cherokee with a swapped-in 1997 4.0L engine runs and drives, but the temperature gauge stays at the cold mark. Replacing the thermostat did not help. The 1996 head had an extra coolant sensor near the firewall that the 1997 head lacks, leaving that connector unused. The expert confirmed the Cherokee uses a separate sender and suggested finding a thermostat housing with a sensor port or wiring the gauge to the 1996 ECT sender instead of drilling the head.
