I have a 96 Jeep Grand Cherokee and while changing the spark plugs I mixed up the wires to the distributor. What order do the wires go in?
Aug 10, 2006 at 12:23 AM
Reconnect the spark plug wires in firing order 1-5-3-6-2-4. The distributor rotates clockwise when viewed from above. The terminal closest to the engine is cylinder 6, then clockwise 2, 4, and 1 (farthest from the engine); cylinders 5 and 3 are the rear terminals.
The owner of a 1996 Jeep Grand Cherokee mixed up the spark plug wires at the distributor while changing plugs and asked for the correct order. The expert gave firing order 1-5-3-6-2-4, noted clockwise distributor rotation from above, and described terminal positions: 6 closest to the engine, then 2, 4, and 1 farthest away, with 5 and 3 at the rear.
