I had a similar problem with my 1996 Cherokee, fixed it. I responded to another post with a similar problem ALSO, so I'll refer you to that post instead of repeating the same info again. Go to the post with the title "Won't Start" near the bottom of the first page. If you don't see it, check the second page in case it's been shifted back.
Your self-diagnostic code "11" means "No crank reference signal to computer", meaning that your Crankshaft Position Sensor is most likely bad. Mine was located near the top of the transmission bell housing, driver's side, accessible from underneath, has two bolts holding it in place, and will have a small diameter wire harness leading from it up to the top of the engine. Check for the dirty connector, melted or broken wires (the harness runs across part of your intake manifold). If you should decide to replace it, it's about 60.00 at the auto parts store.
Good Luck.
SPONSORED LINKS
Saturday, August 11th, 2007 AT 2:47 PM
