1996 Jeep Grand Cherokee Spark Plug Wire Order Fix
JOHANNSENTODD
I have a 96 Jeep Grand Cherokee and while changing the spark plugs I mixed up the wires to the distributor. What order do the wires go in?
Aug 10, 2006 at 12:23 AM
MIKEYBDMAN
  • 623 POSTS
[quote:be09c91169="johannsentodd"]I have a 96 Jeep Grand Cherokee and while changing the spark plugs I mixed up the wires to the distributor. What order do the wires go in?[/quote:be09c91169]
Ok, the firing order is 1-5-3-6-2-4
The distributor turns clockwise as viewed from above. If the image I have is true to real life, the closet plug to the engine, is the 6. Then as you go clockwise it is 2 then 4 then 1. The 1 is the furthest away from the engine. Then of course the 5 and then 3 are the rear ones.
Hope this helps.
Aug 11, 2006 at 11:44 AM
Suggested Repair
Reconnect the spark plug wires in firing order 1-5-3-6-2-4. The distributor rotates clockwise when viewed from above. The terminal closest to the engine is cylinder 6, then clockwise 2, 4, and 1 (farthest from the engine); cylinders 5 and 3 are the rear terminals.
Conversation Summary
The owner of a 1996 Jeep Grand Cherokee mixed up the spark plug wires at the distributor while changing plugs and asked for the correct order. The expert gave firing order 1-5-3-6-2-4, noted clockwise distributor rotation from above, and described terminal positions: 6 closest to the engine, then 2, 4, and 1 farthest away, with 5 and 3 at the rear.
