Hi, I have a Jeep Cherokee sport 2001. My idle speed seems very low, I've read in my hand book that it should range between 700-900 and mine is in the low 500. I've replaced the idle air control motor and cleaned the throttle body but the result is still the same. I took the car to a mechanic for a check since my transmission was acting up after scanning the computer he found the following error codes P1698-NO BUS MESSAGE FROM TRANS CONTROL MODULE and P1698-NO BUS MESSAGE FROM TCM (without the check engine light beign on). He tried to clear them but it would not let him, so he advised me to take the car to a car electrician. I recently found out that the car has been in an accident with the prior owner. I guess I would like to know if all these issues are connected somehow and what I should do. Thanks in advance.
Jun 15, 2007 at 2:51 AM
