[quote:3d4d0674ca="hardie775"]this concerns a 91 comanche. inline 6. automatic with about 150, 000 miles. 4.0 liter. same a a cherokee.
yesterday i stalled from overheating and the overflow of the overflow resevoir was overflowing. i topped off the water and shortly their after, 5 minutes maybe, same thing.
the upper rad hose is hot, so i thought not the thermostat, but when i pinch it, i do not feel a surge of pressure upon release. so i replaced the water pump. still the same. and still no surge when i pinch the hose.
the radiator was replaces about 3-4 years ago, so was the water pump. other than the new water pump installed this morning. new rad cap about 2 weeks ago and a new transmission filter about a month ago.
all help appreciated[/quote:3d4d0674ca]
Double check the thermostat could be a bad new Stat again. Never know
Could be air lock in the cooling system, try bleeding it for start see below.
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks
Sep 20, 2007 at 9:41 AM
