Jeep Cherokee 2.5 Diesel Glow Plugs
XAVIERLENTH
hi there.. any idea how to remove and test glow plugs..
also a lound noise when starting is this the bendix in the starter? how would this be fixed..
also the buzzer which tells you the lights are on when the door opens dosnt work.
and seat belt warning.. any ideas..
thanks :P 8)
Mar 23, 2006 at 5:54 PM
PEPPERMRJ
  • 1,158 POSTS
To check the glow plugs, disconnect the power cable to the top of each one and check the resistance between the central terminal and the outer casing or cylinder head (ground) it should be below 1 ohm. Normally they will start on 3, but if you have 2 down they won't start from cold.
The buzzer could be anything from the light switch, ignition tumbler, the wiring, to a bad buzzer itself.
Mar 25, 2006 at 11:53 AM
Suggested Repair
Disconnect the power cable at the top of each glow plug and measure resistance between the central terminal and the outer casing or cylinder head. It should be below 1 ohm. The engine may start with three working plugs, but two failed plugs can prevent a cold start. For the lights-on buzzer, check the light switch, ignition tumbler, wiring, and the buzzer itself.
Conversation Summary
The owner of a Jeep Cherokee 2.5 diesel asked how to remove and test the glow plugs, whether a loud starting noise was the starter bendix and how to fix it, and why the lights-on door buzzer and seat belt warning did not work. The expert explained a resistance test for the glow plugs and said the buzzer fault could be the light switch, ignition tumbler, wiring, or the buzzer. The starter noise and seat belt warning were not addressed.
