thanks
1998 Jeep Cherokee High Mileage Buy
thanks
This question is difficult to answer. Everything can be working properly and as designed at this time and then fail a day later. If you have a shop inspect it, they can tell you it appears good, but they can't guarantee how long it will last.
With this many miles on the vehicle, there is more to consider other than just the engine or transmission. Keep in mind, the wheel bearings, transfer case, braking system, electrical system including the ECM, and everything on the vehicle has a lot of miles.
When you look at a vehicle with this many miles, it should only be purchased if the price is right, things are working properly when purchased, and with the idea that anything can fail at any time. In other words, prepare yourself for repairs regardless of how it is running now. Everything has a limit and eventually fails.
Suggested Repair
Have a shop inspect the 1998 Jeep Cherokee, but do not expect any guarantee of remaining life. With about 400,000 km, buy only if the price is right and everything currently works, and budget for possible failures of the engine, transmission, wheel bearings, transfer case, brakes, and electrical system including the ECM. Engine replacement is not automatically required if it is running properly.
Conversation Summary
A buyer asked whether a Jeep-certified inspection of a 1998 Cherokee with about 400,000 km would confirm the engine would last another 5,000 km, or whether the engine should be replaced. The expert said an inspection can only assess current condition and cannot guarantee future reliability. High-mileage parts beyond the engine and transmission can fail at any time, so the vehicle should be purchased only if the price is right and the buyer is prepared for repairs.
