1999 Jeep Cherokee Cuts Out on Turns
MONK
I have a 1999 Jeep Cherokee, 5 speed stick, 4 ltr inline 6, 4 wheel drive with 172,000 miles. The vehicle at 1/4 tank of gas cuts out dramatically on turns and just as quickly revives. This sometimes also happens on cold starts going forward. I know that this problem has been addressed in the past,with the indication of a faulty fuel pump modulater which is in the gas tank.
This happens quickly and recovers quickly, can the pressure drop that fast ? In the old days I would have thought it to be a sticky float in the carb.
Thanks for your help!
Mark
Jun 8, 2007 at 11:08 AM
2CARPRO JACK
  • 11,533 POSTS
The pumps are high pressure, so they recover very quickly. Sounds like there is less gas than gauge reads if the engine cuts out and catches back up.Might be tim eto drop the tank and see if the tank module is good, and look in the tank to be sure no baffles are loose causing the float for gauge to stop before above empty
Jun 9, 2007 at 1:55 AM
Suggested Repair
Drop the fuel tank and inspect the in-tank fuel pump module. Also check for loose tank baffles that can stop the gauge float before the tank is empty, since the cutting out may mean less fuel is present than the gauge shows. High-pressure pumps recover quickly once fuel is available.
Conversation Summary
The owner of a 1999 Jeep Cherokee said the engine cuts out sharply on turns at about a quarter tank and sometimes on cold starts, then recovers quickly, and suspected the in-tank fuel pump module. The expert said high-pressure pumps recover very quickly and that the gauge may read higher than the actual fuel level. The suggested next step is to drop the tank, inspect the module, and check for loose baffles affecting the gauge float.
