Brake lights
COJ
  • JEEP CHEROKEE
I have a 1994 jeep cherokee sport inline 6 4.0 with 167000 miles on it. During the day time when I am not using the lights, and press the brake pedal, all of the lights inside and outside all come on and at night when the lights are on, the brake lights will not go off. I have had the light (pull) switch changed, as well as the combination switch (turn signal switch) on the steering column and I have had the rear brakes replaced. I have checked all of the bulbs, the fuses, I have disconnected the brake switch on the pedal and nothing works. What else can I check?
Sunday, November 11th, 2007 AT 6:33 PM
My best offer here is try jiggling the main wire harness that don't work. You need to bring it in-it needs an expert electrician to troubshoot this problem
Check the brake switch with the use of a test light-one wire connector to it should have power not both-if both has power adjust the switch if it continues replace the brake switch.
Good Luck
Sunday, November 11th, 2007 AT 6:57 PM
