1999 Jeep Cherokee P0740 Stall
AUFIN
Have a 99 4.0 jeep cherokee sport running around with the 0740 code showing that my son has been ignoring . Recently it has been shutting down while on the road. No other code seems to be showing up, so my question is just how much trouble can the TCC solenoid cause, and could this be a part of the reason the car is shutting down?
Feb 26, 2007 at 10:31 AM
CHEVY22
  • 1,375 POSTS
yup sure could be , i would get it to the shop as soon as you can to prevent any further internal damage , my kid does the same thing lol
thanks, jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others
Feb 26, 2007 at 10:36 AM
AUFIN
In doing a bit of internet research on the subject of the TCC I've read replies that touch on the possibility of shutting the engine down, but don't elaborate. so I'm having a bit of trouble making the connection.
I'm old school shade tree, so troubleshooting problems that involve certain sensors tend to not make a lot of sense till someone explains the interconnection. The TCC shutting down the engine must be some sort of safety factor. Am I on the right track?
Feb 26, 2007 at 1:25 PM
CHEVY22
  • 1,375 POSTS
the ecm gets input from all sensors on the vehicle , when it gets this info it sends output in a milisecond to all sensors and a fauly sensor like the tcc could be locking the converter when its supposed to be unlocked causing the stall , or visa versa if that makes any sense
code p0740 will set if tcc cannot achieve desired rpm drop in engine rpm when tcc solenoid is near maximum duty cycle
hope this helps , check the fluid and see how it looks
jim
Feb 26, 2007 at 1:43 PM
Suggested Repair
Have the transmission inspected promptly to avoid further internal damage. Check the transmission fluid condition. A faulty TCC solenoid can lock the torque converter when it should be unlocked and stall the engine; P0740 means the TCC did not produce the expected engine RPM drop near maximum solenoid duty cycle.
Conversation Summary
The owner of a 1999 Jeep Cherokee with code P0740 asked whether a TCC solenoid could cause the engine to shut down while driving. The expert said it could, because a faulty TCC can lock the converter at the wrong time, and advised a shop visit soon plus checking the fluid.
