96 Grand Cherokee won't start
JEREMIAH06
  • 1996 JEEP CHEROKEE
96 GC, Auto, L6
I went to start my car in the morning and it would turn over but it will not fire. Also the fuel gauge shows as empty but the tank has 8-10 gal of gas. I tried to check if the fuel pump was getting voltage, I did not detect any but I may not have had a good test. I replaced the fuel pump relay with no effect. What are the other poss causes and ways to check/repair. Sometimes when giving it gas it would hesitate a little and then go. Thanks for the help.
Sunday, June 10th, 2007 AT 1:20 PM
When it refuses to start check for spark and fuel, then comeback.
Monday, June 11th, 2007 AT 7:06 AM
JEREMIAH06
OK I'll check that, But would that have an effect on the fuel gauge?
Monday, June 11th, 2007 AT 7:19 AM
No it has nothing to with fuel level-you need cranking speed, compression, fuel and ignition to get an engine to start.
Monday, June 11th, 2007 AT 11:03 AM
