1994 Jeep Cherokee Popping Sound
If you are prepaired to do the work yourself, be sure to get yourself a repair book for your model at the auto parts store. you will need the guidance offered in the book, especially if it your first time doing U-joints.
Always, be sure to follow the recomendations of marking the drive shaft in relation to the yolk on the rear axel. if you put it on the wrong way around, you will end up with a vibration.
This will be your first step in eliminating the popping sound. It is a fairly simple, inepensive repair that should probably be done anyhow because of how many miles are on the vehicle.
If you do this repair, or have it done for you, please post your results here.
If it does not stop the popping noise, their are a few other ideas I have, but they are pretty involved and quite messy.
Suggested Repair
Inspect and replace the universal joints, a common wear item at this mileage. Mark the driveshaft relative to the rear axle yoke before removal so it is reinstalled in the same orientation and does not cause vibration. Use a model-specific repair manual if doing the work yourself. If the popping continues, further diagnosis is needed.
Conversation Summary
A 1994 Jeep Cherokee with about 146,000 miles makes a popping sound while moving, most noticeable when slowing down, after sitting unused for a year. The owner also mentioned a new battery and possible strut needs. The expert said the noise sounds like worn universal joints and recommended replacing them as a simple, inexpensive first step, marking the driveshaft to the rear axle yoke so it is not installed backward. If the noise remains, other more involved causes would need to be checked.
