Iyou have known issues with the shift linkage, you may be farther off than you know. Also if the positive cable was that bad, the negative one is worth a look. Especially where it conects. At both ends, see if the car will start with a jump. The starter itself can also be your problem.
SPONSORED LINKS
Friday, August 15th, 2008 AT 4:40 PM
