2001 Jeep Cherokee Ignition Coil C and A
2001 JEEP CHEROKEE
117,300 MILES • 6 CYL • 4WD • AUTOMATIC
KENNYS1
My check engine light comes on and stays on the trouble code is:
P0353 Ignition Coil C Primary/ Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/ Secondary Circuit Malfunction
P1391 Description not available
Jul 6, 2010 at 7:01 AM
INTERNETMECHANIC
  • 700 POSTS
Any driveability issues? Does it start and run ok? If it cranks good but won't start, check the dark green wire with orange tracer at the coil assembly for voltage, engine cranking?
The P1391 is intermittent cam or crank signal, I'd have to catch the problem in the act to determine what is going on.
You can do an ohms test at the coil rail terminals not the wiring connector, unplug it. Do ohms test between the terminal for dark green wire with orange tracer and each one of the other terminals, one at a time. If the ohms spec isn't between .6 and .9 ohms, my info says to replace coil rail assembly. I wouldn't replace anything without trying to be sure.
Jul 6, 2010 at 7:52 AM
KENNYS1
There are no driveability issues it cranks, starts and runs fine.
Jul 6, 2010 at 3:19 PM
INTERNETMECHANIC
  • 700 POSTS
I guess you need to let the dealer look at it. Intermittent stuff can be hard to get a handle on.
Jul 7, 2010 at 2:09 AM
