1995 Jeep Cherokee COIL
MOMMY2BE
  • 1995 JEEP CHEROKEE
  • V8
  • 4WD
  • 11,700 MILES
I put a new Coil on and in two days it burns. And the thing the belt goes on it turns and then stops and when it stops the truck shake and then it starts going again.
Sunday, September 20th, 2009 AT 8:34 PM
  • 110,055 POSTS
The voltage to the coil is controled by the PCM. As far as the belt, does it only happen when the AC is on?
Friday, September 25th, 2009 AT 7:17 AM
MOMMY2BE
No it happemns when the ac is off. The truck will work fine for a while but after a couple days or so the coil burns. We put a new one and it work just fine I dont understand. And what is the PCM and where is it at.
Sunday, September 27th, 2009 AT 9:09 PM
  • 110,055 POSTS
The PCM is the powertrain control module in the vehicle. It is the main computer for the engine / trans. Usually, it's located under the hood on an inner fender well.
Sunday, September 27th, 2009 AT 9:28 PM
