2000 Jeep Cherokee Wont start
BCS0262COP
  • 2000 JEEP CHEROKEE
  • 6 CYL
  • 200,000 MILES
My cherokee for some reason will not start. When the key is turned to start the car you hear a click. The dash lights and all other electrical components work. When u you turn the key to the off position I hear several clicking noises coming from behind the dash and the rpm and speedometer needles willl go from 0 to there max position to 0. The baterry and starter are both good. Please HELP
Received a reply in regards to this posting from an individual. I checked the battery and terminals and replaced both prior to the original posting. This vehicle does not have an after market alarm, but does have a factory alarm. I am unsure how to disable this alarm unit. I pulled the fuse for the alarm and the fuse was not blown.
Saturday, January 23rd, 2010 AT 4:02 PM
BMRFIXIT
  • 19,053 POSTS
Will not crank
or it does crank but no start
disconnect battery and check terminals
reconnect and try to start
check security system and if any after market alarm system
Wednesday, January 27th, 2010 AT 8:18 PM
