2000 Jeep Cherokee won't start
DRIDOG
  • 2000 JEEP CHEROKEE
  • 6 CYL
  • 123,000 MILES
I have a 2000 jeep grand cherokee that will not start.
I do not see a distributor, spark plug wie or spark plug. There appears to be am bar that may house the coils and also connect to the plugs. I am not fmiliar with this setup. The jeep was running fine, woke up one morning tried to start and it will crank but does not hit. Sprayed starting fluid in carb still nothing please help
Saturday, November 15th, 2008 AT 10:23 AM
JNOVACK
  • 723 POSTS
Which engine do you have the 3.7 or 4.0 the 3.7 has a coil for each plug it would be on top of engine you will have to unplug one of them and check the ohms should be between 250-1000 and also check to see if you are getting fuel pressure should be 39-41 psi also check compression it should be 120-150 psi normal, 100 psi min, 30 psi max. Variation between cylenders
Saturday, November 15th, 2008 AT 4:38 PM
