2000 Jeep Cherokee sport
CRYSTALAUTUMN
  • 2000 JEEP CHEROKEE
My check engine light came on p0705 and p1694 what should I do to fix?
100,000 6 cylinder 2000 jeep cherokee sport
please help I cant seem to get answers
Tuesday, August 7th, 2007 AT 11:03 AM
SERVICE WRITER
  • 9,123 POSTS
Motor size?
How long has the light been on?
Any other symptoms?
Tuesday, August 7th, 2007 AT 11:08 AM
CRYSTALAUTUMN
The engine light just came on yesterday and keeps going on and off, mainly on the engine size is a 4.0 liter. No symptoms that I can see
Tuesday, August 7th, 2007 AT 11:15 AM
SERVICE WRITER
  • 9,123 POSTS
The p1694 has to do with no communication between 2 modules. It is probably a symptom of po705. You may need a scanner to be able to diagnose this code. It has to do with the transmission control module not knowing what gear it's in by the gear selector. Fair chance of the transmission range sensor being bad. I would start by checking the connections at the transmission control module and the transmission range sensor for damage/corrosion first.
Tuesday, August 7th, 2007 AT 12:02 PM
