2000 Jeep Cherokee Cold Start Delay
KOPERTONE1
I have a 2000 Jeep Cherokee with 127,000 miles. The check engine light came on about a week and a half ago. About a few weeks before that i noticed it took a second or two longer to turn over and start then it used to when it was completely cold. Once it was on it ran fine, and if i shut it off and turned it on while still fairly warm it started normal. I am about to take it to the dealer for that and a couple other issues, any ideas so I can bring them up? Thanks
Aug 7, 2007 at 1:58 PM
SERVICE WRITER
  • 9,123 POSTS
It sounds like a bleed down problem at the fuel pump. They will have to diagnose it anyways. Make sure you explain it ahead of time, CLEARLY be on the same page at this point. The truck needs to be dropped off the night before and be cold, so it can be tested when the problem is happening with test equipment hooked up.
Aug 8, 2007 at 4:38 AM
Suggested Repair
Have the dealer diagnose a possible fuel pump bleed-down. Drop the Cherokee off the night before so it is fully cold, explain the cold-start delay clearly, and have test equipment connected when the problem occurs.
Conversation Summary
The owner of a 2000 Jeep Cherokee with 127,000 miles reported a check engine light and a one- to two-second longer crank only when completely cold. Once running it was fine, and warm restarts were normal. The expert suspected fuel pump bleed-down and advised an overnight drop-off so the cold condition can be tested with equipment connected.
