Sounds like the vehicle is bleeding off the fuel pressure try priming the pump before starting.
Turn the key forward and leave on on postion for 5 secs then turn off, repeat this five times, does it fire up better? If so its bleeding off pressure.
Perform a injector leak test and a fuel pressure regulator leak test.
SPONSORED LINKS
Monday, March 3rd, 2008 AT 7:02 PM
