1999 Jeep Cherokee difficult to start
HUNSTAGAB
  • 1999 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 276,235 MILES
My jeep is hard to start. Sometimes it starts right away and other times it will not start at all. I have replaced the rotor, distributor cap and spark plugs. I'm not sure but there are times I finally get it started and drive down the road and it will stall most of the time if I get it started it will stay running without further problem. This has been a very reliable jeep without any problems other than simple maintenance so most everything is factory.
Tuesday, September 14th, 2010 AT 1:41 PM
Next time it refuses to start do below don't wait to determine what's cauisng it
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, If you can hear the fuel pump come On- check the fuel pressure with a fuel pressure tester designed for your fuel system to rule out the fuel filter/fuel pick-up strainer/fuel pump/pressure regulator and also listen to the injector/s are they pulsing or hook up a noid light and see if it flashing, If you don't hear the fuel pump, check the fuel pump fuse and fuel pump relay-Depends on what type ignition system is yours, No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, camshaft and crankshaft position sensors and computer Note: If it doesn't apply to your vehicle disregard it meaning if it doesn't come with one ignore it and continue testing
Tuesday, September 14th, 2010 AT 3:25 PM
