1998 Jeep Cherokee Steering Wheel Shaking
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
DANNY4H
At low speeds i can hear a vibration but as soon as i get above 55 the wheel shakes violently. When i take corners it shakes also no matter what speed. Mostlly the shaking is on the passenger side. Please help, i have replaced all the u joints aligned the front end and balanced all the tires.
Thanks
Dan
Aug 12, 2008 at 4:28 PM
  • 31,937 POSTS
Hi there,
If you have a vibration in the steering wheel, the problem will be in the steering linkages, suspension, front wheels or bearings. If it shakes under braking it will be the front rotors at fault, start with having these items inspected for any faults.
mark (mhpautos)
Aug 12, 2008 at 4:49 PM
DANNY4H
ok how much will a bearing replacement cost and can i do it by myself?? my grandfather says its the inner bearing but i want to make sure
[quote:1042ffd450="mhpautos"]Hi there,
mark (mhpautos)[/quote:1042ffd450]
Aug 14, 2008 at 4:52 PM
  • 31,937 POSTS
Hi there,
if you suspect faulty bearings, first jack up the wheel and feel for any play, (top to bottom) if there is excessive play service the bearings if OK, have a wheel balance inspection done.
mark (mhpautos)
Aug 14, 2008 at 5:00 PM
