1998 Jeep Cherokee BAD SHAKE IN STEERING - JEEP
1998 JEEP CHEROKEE
NUTS4BOLTS
  • 7 POSTS
Steering problem
1998 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
Steering shakes really bad when hitting bumps in 1998 Jeep Cherokee? Any help greatly appreciated.
Oct 26, 2008 at 11:51 AM
BLACKOP555
  • 10,386 POSTS
check for looseness in the tie rods and other front end steering components
if those are all good i would replace the steering dampner.
Oct 26, 2008 at 1:09 PM
JASONRAY
  • 213 POSTS
Don't overlook the shocks. They're job is to hold the tire on the ground after hitting bumps. If ONLY one shock on the front is BAD, That tire will try to bounce more than the other one and feel like a shake in the steering because you feel it in the steering wheel. Put a knee on the bumper and push down real hard and see how many bounces it has after you do that. It should come back up and stop on the way back down. If it does more, consider replacing the shocks.
Oct 28, 2008 at 8:19 PM
EXTRUDEDCOW
  • 27 POSTS
This sounds like this may be a case of 'death wobble' as it's referred to by some members of the Jeep community. It's usually caused by a worn component in the front suspension. I would recommend having the front suspension and steering components looked at, and have the steering stabilizer replaced.
The shocks and steering stabilizer can be relatively inexpensive and easy to replace. Although they're not typically the primary cause of the wobble, if they've failed they can be a contributing factor.
Oct 28, 2008 at 9:47 PM
