Monday, September 6th, 2010 AT 8:30 AM
I AM HAVING A PROBLEM WITH MY 1997 JEEP GRAND CHEROKEE 4.0L ENGINE CUTTING OFF WHEN DRIVING. ONCE IT CUTS OFF I AM UNABLE TO START IT AGAIN FOR A FEW MINUTES AND IF IT DOES CUT BACK ON I HAVE TO CRANK IT BEFORE IT ACTUALLY STARTS AND THEN IT SEEMS TO IDLE RIGHT FOR A COUPLE MINS THEN JUST SHUTS OFF AGAIN. IT SEEMS TO BE A LOSS OF POWER AND I AM VERY CONFUSED. I HAVE REPLACED THE ALTERNATOR, BATTERY, IGNITION COIL, CRANKSHAFT SENSOR, MUFFLER, CAT. CONVERTER, FUEL PUMP, FUEL FILTER, AIR FILTER, INTAKE AND VALVE BODY GASKETS, SPARK PLUGS & WIRES, ASD RELAY, AND THE ENGINE CONTROL MODULE(ECM). I HAVE ALSO CLEANED THE THROTTLE BODY AND THE INJECTORS. PLEASE HELP ME!
