Yes it probably is, check the relay, fuse and the connector, it may be loose try having someone keep turning the key on and you wiggle the connector and see if it turns on and off if it does replace the connector!
If thats not it check for voltage at the connector if all is good then change the pump, but if no voltage then check the things mentioned above, the relay switch and fuse.
SPONSORED LINKS
Tuesday, November 20th, 2007 AT 10:09 PM
